  3. Connectivity Mark Net for temporary layers
  • Views 15371
mvalery
mvalery over 15 years ago
I'm creating a temporary layer on the fly if a user wants to combine layer stackups for EM simulation. As an example M7 anded with M8 that enclose V7 will create a temporary LSW layer M7_M8. I've been trying different technology file skill commands to create the correct connectivity between the new layer and the old: M7 or M8 butting M7_M8 is a connection. Using techSetEquivLayer it works a little: techSetEquivLayer(techId list("M8" "M7_M8")) techSetEquivLayer(techId list("M7" "M7_M8")) Connectivity->Mark->Net, click on a M7_M8 fig, and it marks correctly. Connectivity->Mark->Net, click on a M8 fig, marks stop at the M7_M8 fig. If I create two M7_M8 figs that overlap, Connectivity->Mark->Net, click on a M7_M8 fig, mark stops at the clicked fig. Any answers or guess are appreciated. Thanks, Mark
  • skillUser
    skillUser over 15 years ago
     Hi Mark,
    I don't know which version you are using, and this could have a bearing on the answer. However, in both IC5141 and IC61x versions the Mark Net command has an Options form (F3 if the form is not shown) - and both have an option "Via Layers used by Mark Net" - Select Via Layers. Perhaps you can play with this to get the desired results?
    Hoping it helps,
    Lawrence.
  • mvalery
    Lawrence, I'm using IC614. "Vias layers used by Mark Net" gives me a list of defined vias to enable or disable. There are no defined vias for this temporary layer. Connectivity is only through the butting of the metals layers that the combined metal layer was made from. I removed the EquivLayer settings: techSetEquivLayers( techFileID list()) Added temporary layer "aa" as via: Vaa_ID=techCreateStdViaDef(techFileID "Vaa" "Metal7" "Metal8" list("aa" 0.36 0.36) list(1 1 list(0.36 0.36)) list(0.08 0.08) list(0.1 0.1) list(0.0 0.0) list(0.0 0.0) list(0.0 0.0)) Now M7 butting aa butting M8 works. M8 butting aa butting M8 does not because a valid via connection was not made. Is there something I'm missing in the tech file that would enable this temporary layer "aa" to have connectivity to another "aa" figure that it overlaps? If I have 2 M8 figures that overlap, do Connectivity->mark->Net and click on one of them, they both hilight. This fails for the temp layer. Thanks, Mark
