  3. Assura LVS execution terminated
  • Replies 11
  • Subscribers 133
  • Views 21916
razvanm
razvanm over 15 years ago
I'm trying to run  LVS with Assura for a ring oscillator. I set all the files and i click ok but it doesn't work and i don't know why. I've tried the same run about 2-3months ago and it has worked, but now i guess i'm missing an option or something like that. here is the log file. i guess it has something to do especially with the last warning cellview "name" doesn't exist in cds.lib or lib.defs.
If someone has encountered the same problem and has a solution, please help me with the needed information.
Thank you in advance.
 Log file:
Summary Report: lvsrosc.sum
 RSF           : /home/mihai/testgp/ringosc/layout/lvsrosc.rsf
Library Name : testgp
CDSLIB Path : "/home/mihai/cds.lib"
LIBDEFS Path : "/home/mihai/lib.defs"
Cell Name : ringosc
View Name : layout
Rules File : ./Desktop/gpdk090_v4.5/assura/extract.rul
Options : -exec1 -LVS -cdslib /home/mihai/cds.lib -libdefs /home/mihai/lib.defs
Work Directory: /home/mihai/testgp/ringosc/layout
Operating Mode: Legacy Mode is Off
Starting dfIIToVdb...
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
@(#)$CDS: dfIIToVdb version av4.1:Production:dfII6.1.3:IC6.1.3.500.15 10/08/2010 03:06 (sfrh50) $
sub-version 4.1_USR1_HF13, integ signature 2010-10-08-0235
run on xxxxx from /opt/cadence/assura41-613/tools.lnx86/assura/bin/32bit/dfIIToVdb on Mon Apr 25 11:39:30 2011
*WARNING* ddiProcessOALibDefs: Could not get top libdefs list for reading OA lib.defs
*WARNING* LIB cdsDefTechLib from File /opt/cadence/ic610/share/cdssetup/dfII/cds.lib Line 1 redefines
LIB cdsDefTechLib from File /home/mihai/lib.defs
Insert UNDEFINE cdsDefTechLib
before DEFINE cdsDefTechLib
in /opt/cadence/ic610/share/cdssetup/dfII/cds.lib
Or remove or comment out DEFINE cdsDefTechLib
in /home/mihai/lib.defs
to suppress this warning message.
*WARNING* LIB analogLib from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib Line 1 redefines
LIB analogLib from File /home/mihai/lib.defs
Insert UNDEFINE analogLib
before DEFINE analogLib
in /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib
Or remove or comment out DEFINE analogLib
*WARNING* LIB functional from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib Line 2 redefines
LIB functional from File /home/mihai/lib.defs
Insert UNDEFINE functional
before DEFINE functional
Or remove or comment out DEFINE functional
*WARNING* LIB rfLib from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/spectre/cds.lib Line 6 redefines
LIB rfLib from File /home/mihai/lib.defs
Insert UNDEFINE rfLib
before DEFINE rfLib
in /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/spectre/cds.lib
Or remove or comment out DEFINE rfLib
*WARNING* LIB rfExamples from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/spectre/cds.lib Line 7 redefines
LIB rfExamples from File /home/mihai/lib.defs
Insert UNDEFINE rfExamples
before DEFINE rfExamples
Or remove or comment out DEFINE rfExamples
*WARNING* LIB ahdlLib from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/spectre/cds.lib Line 8 redefines
LIB ahdlLib from File /home/mihai/lib.defs
Insert UNDEFINE ahdlLib
before DEFINE ahdlLib
Or remove or comment out DEFINE ahdlLib
*WARNING* LIB basic from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib Line 1 redefines
LIB basic from File /home/mihai/lib.defs
Insert UNDEFINE basic
before DEFINE basic
in /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib
Or remove or comment out DEFINE basic
*WARNING* LIB US_8ths from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib Line 2 redefines
LIB US_8ths from File /home/mihai/lib.defs
Insert UNDEFINE US_8ths
before DEFINE US_8ths
Or remove or comment out DEFINE US_8ths
*WARNING* LIB hfa3101 from File /home/mihai/cds.lib Line 5 redefines
LIB hfa3101 from File /home/mihai/lib.defs
Insert UNDEFINE hfa3101
before DEFINE hfa3101
in /home/mihai/cds.lib
Or remove or comment out DEFINE hfa3101
*WARNING* LIB raz1 from File /home/mihai/cds.lib Line 7 redefines
LIB raz1 from File /home/mihai/lib.defs
Insert UNDEFINE raz1
before DEFINE raz1
Or remove or comment out DEFINE raz1
*WARNING* LIB avTech from File /home/mihai/cds.lib Line 8 redefines
LIB avTech from File /home/mihai/lib.defs
Insert UNDEFINE avTech
before DEFINE avTech
Or remove or comment out DEFINE avTech
*WARNING* LIB testgp from File /home/mihai/cds.lib Line 9 redefines
LIB testgp from File /home/mihai/lib.defs
Insert UNDEFINE testgp
before DEFINE testgp
Or remove or comment out DEFINE testgp
*WARNING* ddUpdateLibList: Found errors in one or more 'cds.lib' or 'lib.defs' files.
*WARNING* CellView "testgp/ringosc/layout" does not exist in any /home/mihai/lib.defs or /home/mihai/cds.lib files.
***** dfIIToVdb terminated abnormally *****
*WARNING* Translation abnormally terminated!
*WARNING* aveng exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
***** aveng fork terminated abnormally *****
  • Quek
    Quek over 15 years ago
    Hi razvanm
    If it is ok for you, please sync up your cds.lib and lib.defs files as described in my previous post and remove the lib.defs file. The following COS solutions might be of interest to you:
    11417552 : How do I programmatically sync up cds.lib and lib.defs
    11405444 : cds.lib vs lib.defs
    11584544 : IC614 does not understand/read lib.defs
    Best regards
    Quek
