  3. Assura LVS execution terminated
  • Replies 11
  • Views 22212
razvanm
razvanm over 15 years ago
I'm trying to run  LVS with Assura for a ring oscillator. I set all the files and i click ok but it doesn't work and i don't know why. I've tried the same run about 2-3months ago and it has worked, but now i guess i'm missing an option or something like that. here is the log file. i guess it has something to do especially with the last warning cellview "name" doesn't exist in cds.lib or lib.defs.
If someone has encountered the same problem and has a solution, please help me with the needed information.
Thank you in advance.
 Log file:
Summary Report: lvsrosc.sum
 RSF           : /home/mihai/testgp/ringosc/layout/lvsrosc.rsf
Library Name : testgp
CDSLIB Path : "/home/mihai/cds.lib"
LIBDEFS Path : "/home/mihai/lib.defs"
Cell Name : ringosc
View Name : layout
Rules File : ./Desktop/gpdk090_v4.5/assura/extract.rul
Options : -exec1 -LVS -cdslib /home/mihai/cds.lib -libdefs /home/mihai/lib.defs
Work Directory: /home/mihai/testgp/ringosc/layout
Operating Mode: Legacy Mode is Off
Starting dfIIToVdb...
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
@(#)$CDS: dfIIToVdb version av4.1:Production:dfII6.1.3:IC6.1.3.500.15 10/08/2010 03:06 (sfrh50) $
sub-version 4.1_USR1_HF13, integ signature 2010-10-08-0235
run on xxxxx from /opt/cadence/assura41-613/tools.lnx86/assura/bin/32bit/dfIIToVdb on Mon Apr 25 11:39:30 2011
*WARNING* ddiProcessOALibDefs: Could not get top libdefs list for reading OA lib.defs
*WARNING* LIB cdsDefTechLib from File /opt/cadence/ic610/share/cdssetup/dfII/cds.lib Line 1 redefines
LIB cdsDefTechLib from File /home/mihai/lib.defs
Insert UNDEFINE cdsDefTechLib
before DEFINE cdsDefTechLib
in /opt/cadence/ic610/share/cdssetup/dfII/cds.lib
Or remove or comment out DEFINE cdsDefTechLib
in /home/mihai/lib.defs
to suppress this warning message.
*WARNING* LIB analogLib from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib Line 1 redefines
LIB analogLib from File /home/mihai/lib.defs
Insert UNDEFINE analogLib
before DEFINE analogLib
in /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib
Or remove or comment out DEFINE analogLib
*WARNING* LIB functional from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib Line 2 redefines
LIB functional from File /home/mihai/lib.defs
Insert UNDEFINE functional
before DEFINE functional
Or remove or comment out DEFINE functional
*WARNING* LIB rfLib from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/spectre/cds.lib Line 6 redefines
LIB rfLib from File /home/mihai/lib.defs
Insert UNDEFINE rfLib
before DEFINE rfLib
in /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/spectre/cds.lib
Or remove or comment out DEFINE rfLib
*WARNING* LIB rfExamples from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/spectre/cds.lib Line 7 redefines
LIB rfExamples from File /home/mihai/lib.defs
Insert UNDEFINE rfExamples
before DEFINE rfExamples
Or remove or comment out DEFINE rfExamples
*WARNING* LIB ahdlLib from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/spectre/cds.lib Line 8 redefines
LIB ahdlLib from File /home/mihai/lib.defs
Insert UNDEFINE ahdlLib
before DEFINE ahdlLib
Or remove or comment out DEFINE ahdlLib
*WARNING* LIB basic from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib Line 1 redefines
LIB basic from File /home/mihai/lib.defs
Insert UNDEFINE basic
before DEFINE basic
in /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib
Or remove or comment out DEFINE basic
*WARNING* LIB US_8ths from File /opt/cadence/ic610/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib Line 2 redefines
LIB US_8ths from File /home/mihai/lib.defs
Insert UNDEFINE US_8ths
before DEFINE US_8ths
Or remove or comment out DEFINE US_8ths
*WARNING* LIB hfa3101 from File /home/mihai/cds.lib Line 5 redefines
LIB hfa3101 from File /home/mihai/lib.defs
Insert UNDEFINE hfa3101
before DEFINE hfa3101
in /home/mihai/cds.lib
Or remove or comment out DEFINE hfa3101
*WARNING* LIB raz1 from File /home/mihai/cds.lib Line 7 redefines
LIB raz1 from File /home/mihai/lib.defs
Insert UNDEFINE raz1
before DEFINE raz1
Or remove or comment out DEFINE raz1
*WARNING* LIB avTech from File /home/mihai/cds.lib Line 8 redefines
LIB avTech from File /home/mihai/lib.defs
Insert UNDEFINE avTech
before DEFINE avTech
Or remove or comment out DEFINE avTech
*WARNING* LIB testgp from File /home/mihai/cds.lib Line 9 redefines
LIB testgp from File /home/mihai/lib.defs
Insert UNDEFINE testgp
before DEFINE testgp
Or remove or comment out DEFINE testgp
*WARNING* ddUpdateLibList: Found errors in one or more 'cds.lib' or 'lib.defs' files.
*WARNING* CellView "testgp/ringosc/layout" does not exist in any /home/mihai/lib.defs or /home/mihai/cds.lib files.
***** dfIIToVdb terminated abnormally *****
*WARNING* Translation abnormally terminated!
*WARNING* aveng exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
***** aveng fork terminated abnormally *****
  • SharksFan
    SharksFan over 15 years ago
    Have you run virtuoso with the same cds.lib file ( /home/mihai/cds.lib )?  It seems Assura cannot find your testgp/ringosc/layout anywhere when using that set of libraries.
    Also, you have many warnings showing that entries in the lib.defs file are already previously defined elsewhere.  Why don't you comment them out of that file so you can have a cleaner output and make it easier to find the real issues?
  • razvanm
     thank you for the reply
    i commented those entries in lib.defs, it says skipping skipping etc.
     these are the last 3 warnings
    p { margin-bottom: 0.08in; }
    what do you mean run virtuoso with the cds.lib file? the simulations on the schematic with ade work like before, also for this layout the assura drc works , so for the drc it finds the cellview i presume.
  • Quek
    Quek over 15 years ago
    Hi razvanm
    Would you please upload the rsf files for drc and lvs runs? Please use the upload function, not cut and paste.
    Quek
  • razvanm
     rsf for lvs run (saved as text for upload)
    • lvsrosc.txt
  • razvanm
    and this is for drc.
    thank you
    • drcg.txt
  • kamit
    kamit over 15 years ago
    Hi All, You may try using only cds.lib and not lib.defs. Set following env variable: Unix% setenv DD_USE_LIBDEFS NO and then start the tool. Cheers, -Amit
  • razvanm
    hy,
    where can i set this, and how can i revert to the old setting in case it doesn't work?
    thank you
  • Quek
    Hi razvanm
    Thanks for the files. You can use DD_USE_LIBDEFS shell variable as follows:
    a. Use a text editor (e.g. vi, gvim, nedit, etc) to open up the hidden file .cshrc in /home/mihai
    b. Add the following line:
    c. Save the file
    d. Re-source the .cshrc file by entering the following in a terminal window:
    terminal_window>source ~/.cshrc
    e. Start Virtuoso
    You can revert back to the old settings by simply commenting or removing the DD_USE_LIBDEFS line from the .cshrc file.
    Alternatively, in the library manager, go to "Edit->Library Paths". In the form that appears, go to "File->Save As". Select both "lib.defs" and "cds.lib" to be saved. After saving the files, remove lib.defs file from the working directory. Hope that this can resolve your problem. There is no need to use lib.defs file. Only cds.lib file should be used.
    Best regards
    Quek
  • kamit
    Hi razvanm,
    I hope Queks explanation helped.
    Thanks.
  • razvanm
     problem solved.
    thank you all for your help.
    i didn't have lib.defs in the working directory. once i've copied it there it worked.
    regards,
