  3. layer visibility and LSW palette
  • Views 15653
wighou
wighou over 15 years ago
 I can not use the LSW palette to turn a layer invisible. To make a layer unselectable, it works fine. But the visibility options do not work. I see no error in notification zone.
 Any idea ?
wighou
  • skillUser
    skillUser over 15 years ago
    Hi Wighou,
    Which subversion are you using?  It is possible that you have a slightly older version that has a bug in it regarding the Layer Palette. You could try using the SKILL function leSetLayerSelectable() in the CIW?
      l_layerPurposePair ;; this is something like list("metal1" "drawing")
      g_isSelectable     ;; set this to 'nil' for the layer to be unselectable
      [ d_techFileId ]
         => t | nil
    Hopefully this can provide a workaround in the meantime, until we understand why it does not work.
    Best regards,
    Lawrence.
