  3. How to calculate THD using calculator?
  • Replies 7
  • Subscribers 133
  • Views 21839
greatqs
greatqs over 15 years ago
I found the thd() in calculator only has  5 arguments (e.g. from, to, # samples, fundamental frequency).
For example, I'm doing a FFT with sample frequency of 8192KHz with from=1ms to=2ms and fundamental frequency is 5KHz.
I want to calculate the THD within 20 ~ 20KHz instead of 0 ~ 4096KHz which thd() does since it doesn't include Fmin/Fmax arguments.
qs
  • greatqs
    Is there anyone can help? Thanks!
  • cad123
    cad123 over 13 years ago
    Is there somebody who can help me on how to plot THD in spectrw. I have a CMOS OTA design for which I have to evaluate HD3 and THD.
    Thanks!
    Did you actually try using the thd() function? If so, what did you try? Which version of the tools are you using?
  • foxbei1983
    foxbei1983 over 12 years ago
    hi Andrew,
     i've got the same question.
     i'm using version 6.1.5 ISR17 calculator.
    thanks!
  • foxbei1983
    nobody answers this question? please help.
    Your first post appeared at just before 6pm my time, and second after 10pm, having broken the forum guidelines and posted on an old thread. It wasn't clear which of the two questions in this thread you were asking, but given that this forum is covered by Cadence folks in their spare time (and I do have a life outside of work), being quite so pushy is a bit unreasonable.
    If it is urgent, you should go to customer support at support.cadence.com
    If not I will look into this once I'm back from being on vacation tomorrow.
    Andrew ( just before 11pm UK time )
    ShawnLogan over 12 years ago
    The THD, as a parameter, is defined as the rms sum of all the fundamentally related harmonics in a signal. Hence, the function, I believe, computes the total harmonic distortion in a manner consistent with the definition (given the FFT length).
    To compute the harmonic distortion for a lesser number of harmonics or over a particular frequency range, simply determine the power (or value of the dft function) for the relevat harmonics and perform the rms sum to compare it with the power in the fundamental.
    An alternative might be to actually include a filter in your circuit analysis simulation that limits the bandwidth to the range of interest and then use the THD function on its output.
    I hope this provides some help!
    Shawn
    http://www.aspowertechnologies.com/resources/pdf/Total%20Harmonic%20Distortion.pdf
