  3. Mark Net and vias
  • Views 14732
Mark Net and vias
Adrian Nistor
Adrian Nistor over 15 years ago
I have the situation from the top of the attached image , where layer 1 and layer 3 are partial overlapping through layer 2;
When using Mark Net, I hit F3 and select "Display Via Layers" and add the combination: "Layer1 Layer2 Layer3" , then Mark Net works well: When I click over the layer1, Mark Net highlights correctly entire "path" Layer1-Layer2-Layer3
BUT
(the bottom part of the attached image)
if, in place of the layer2 shape, I use a VIA (Create - Via; the two main layers defind in tech for this via are different than Layer1 and Layer3) which has inside it the layer2, then MarkNet does not work anymore !! I would espect that markNet would highlight, as in previous example, Layer1, Layer2 inside via, Layer3 but this is NOT hapening;
Currently the only solution is to flatten the VIA and then MarkNet works;
Is this normal? What other solutions there are?
Thank you,
Best Regards,
Adrian.
 Later edit: I'm using IC 6.1.4
I wanted to add this tu Custom Ic Skill , not here; Sorry for the mistake;
