  3. how to fix "No DC path from node `gnd!' to ground"
  • Views 6195
asd1815
asd1815 over 15 years ago
Hi, I am using Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 7.1.1.071 -- 20 May 2009
I am running a simulation in ADE GLX. Each time I run a simulation I get these grounding problems.
I tried to use globalGroundNet in .simrc but that doesn't help because I need to assign "0" and "gnd!" as grounds. I am using a free PDK NCSU 1.6 and I don't want to miss with the netlister.
If I use ADE L I can simply edit the netlist file and fix the global statement by adding 0 gnd! vdd! but if I use GLX each time I run a simulation a new netlist is created.
 Any suggestions?
Thanks!
