  3. Plotting new post-simulation outputs in ADEXL
  • Views 14633
blorbx
blorbx over 15 years ago
Hi, I'm using IC6.1.3.500.11. I have a pretty simple problem which I can't seem to find the solution to. After finishing a simulation in ADE XL and changing or adding some expressions in my 'Outputs Setup' window, the new expressions are not reflected in the 'Results' tab. It seems like the only way to see the result of those expressions is to put the same expression in the calculator and manually evaluating it, or to re-run the simulation. This seems like a simple thing to do, in ADE L, it is quite easy to add an expression after a simulation and then plot it. How can I achieve this with ADE XL? Thanks.
