  3. About floor()
  • Views 17570
About floor()
bobbygang
bobbygang over 15 years ago
I find a strange thing.
When I input
floor(0.1/0.1)
it gives me 1
but if I input
floor((1-0.9)/0.1)
it gives me 0
Why?
How to avoid this situation?
Bobby
    Bobby,
    This is due to floating point rounding errors, found in pretty much every computer language. The trouble is that 0.1 is actually a recurring fraction when represented in binary - so when you do the 1-0.9 you end up with a different answer (very slightly) than 0.1 - due to truncation of the binary digits right at the end. It's similar to the fact that in decimal, if you represented your calculations to 4 decimal places, 3.0/3.0 would be 1.0 whereas if you did (1.0/3.0)*3.0 you'd end up with 0.9999. This can be seen:
    a=1-0.9 => 0.1
    a-0.1 => -2.775558e-17
    sstatus(fullPrecision t)
    a => 0.09999999999999998
    because a is slightly less than 0.1, dividing by 0.1 gives an answer just less than 1, so floor rounds down to 0.
    The answer is to use round(), or to add a small fudge-factor before applying round.
    You might want to read What Every Computer Scientist Should Know About Floating Point Arithmetic
