  3. plot region in mos
  • Views 17067
plot region in mos
DanySF
DanySF over 15 years ago
I make a sweep of some parameters (L, and Id) and I want to plot some DCop data .
So I go to Results browser and I search the usual stuff like : gm, vdsat, cgg, cgs.
I can plot also "region" with RMB->Append but if I send the formula to the calculator then I cannot plot it.
 So in the calculator I have something like :
getData("NM0.mn.region" ?result "dc-dc" )
Why this is not working from Caclulator, but is ok when I do RMB->plot ???
I want to save the formula in to a script (Ocean) and I need the formula to work.
Is this a bug or I'm doing something wrong in my setup ?
I have IC5141 with Spectre and Wavescan. My testbench is from 1 nmos and I make a DC sweep with Id and L as parameter.
  • ywguo
    ywguo over 15 years ago
    Sometimes the tool has weird bugs, especially when we post-process the results. How do you put the formula in the calculator? I will RMB click the signal/parameter in Results Browser, and  choose Calculator. The click the plot button the Calculator to check if the formula is correct.
  • ywguo
    Another point is that this is caused by the pcell and model. Your formula is
    It seems that there is a NMOS transistor named mn inside NM0. I mean this is a subckt in the model definition. Sure the foundry or PDK vendor has done something to ensure the correct operation. But this often causes problem when I try to plot operating points in dc sweep or transient simulation.
  • DanySF
     Thanks.
    I checked today the model and indeed there is a subckt inside. Probably this is one of the reason.
    Thanks !
