  3. OceanX script trouble creating different directories for...
  • Views 14148
OceanX script trouble creating different directories for each run (within foreach loop)
Ivan13
Ivan13 over 15 years ago
Hi
I want to run a script which will measure the same thing but with different initial conditions.
As a way to distinguish the results I thought of separating the results in different directories.
I thought of doing something like this inside foreach loop
         dirname = strcat("/vlsi/vol1/home/user/40nm/trial/" "val" "val2")
         ocnxlResultsLocation( dirname )
where val and val2 are different initial conditions. I would like to see something like this:
/vlsi/vol1/home/user/40nm/trial/00.1
 /vlsi/vol1/home/user/40nm/trial0.10
but I end up seeing it as
/vlsi/vol1/home/user/40nm/trial/valval2
How can I make it work? Do you have a different idea how to distinguish the results?
Thank you for your help ;
====================== Set to XL mode ========================================= ocnSetXLMode() ocnxlProjectDir( "/vlsi/vol1/home/user/simulation" )
ocnxlTargetCellView( "NoiseMargin" "Delay" "adexl" )
 ocnxlResultsLocation( "/vlsi/vol1/home/user/40nm/trial" )
ocnxlSimResultsLocation( "/vlsi/vol1/home/user/40nm/trial" ) ;
====================== Tests setup ============================================
 nodeTypeQ = list(0 0.1)
nodeTypeQB = list(0 0.1)
 foreach(val nodeTypeQ
foreach(val2 nodeTypeQB
desVar("nodeTypeQB" val2)
 desVar("nodeTypeQ" val)
 desVar("dirname" )
dirname = strcat("/vlsi/vol1/home/user/40nm/trial" "val" "val2")
converge( 'nodeset "/Q_9T" nodeTypeQ )
converge( 'nodeset "/QB_9T" nodeTypeQB )
converge( 'nodeset "/QB_8T" nodeTypeQB )
converge( 'nodeset "/Q_8T" nodeTypeQ )
