  3. A question about auCdl - nlSetPcellName ...?
  • Views 2690
Prabhu The ICL
Prabhu The ICL over 15 years ago
  Hi All,
       I am using CADENCE IC514 version. I am trying to customize CDL netlist to full-fill my reqirements. In the process
       I am trying to rename subcircuits model name.
       For example ... please consider the below ...
       original CDL statement :-
       MM1 D G S B NM W=Wfing*fing L=L m=mult  ;(This is a line in the definition of a subcircuit cell)
       required CDL statement :-
       MM1 D G S B rpposab W=Wfing*fing L=L m=mult
       I have gone through the documentation and I found the below procedure ...
       procedure( nlSetPcellName( cv paramNames paramValues )
       let( ( name value (subcktName  ""))
               foreach( (name value) paramNames paramValues
                       subcktName = strcat( subcktName name "_" value  "_")
               strcat(subcktName cv->cellName )
       But I am not getting to which auCdl variable I have to return this('nlSetPcellName' return val) value.
       (I have tried 'auCdlModuleNameMapFunc' variable to rename cell names in my design & it's working. I am looking
       for a similar kind of variable to rename cellname/celltype of a subcircuit).
       I hope the probelm is understandable. If it doesn't I"ll come up with the more information.
       Can someone guide me to achive this ...!
       Thanks in Advance ...
       Prabhakar. K
       ICL Engineer
       SoCtronics Tech.Pvt.Ltd.
       Hyderabad-INDIA
       prabhu.usic@gmail.com
    This is unlikely to help, since this is for the case where you have schematic pcells,  which would result in unique subckts in the netlist for each variant. What you're describing is just a simple MOSFET.
    What you are trying to do is change the  modelName in the CDF. Here's how:
    1. Tools->CDF->Edit CDF
    2. Change from Effective to Base
    3. FIll in the library/cell name of the transistor
    4. Go to the Simulation Information section and hit Edit
    5. Pick "auCdl" as the simulator/netlister
    6. Change the modelName field from NM to rpposab
    7. OK this form and the main edit CDF form
    That's it.
  • Prabhu The ICL
    As I don't have permission to the 'analogLib', I copied it to another library (ex: soc_anlogLib). Now I did exactly what you described in the mail. This has solved the probelm.
    Thank you very much for your valuable suggestions.
    Thanks & Regards ...
    Prabhakar. K
    IC Layout Engineer
    Hyderabad-INDIA
