  3. In valid dev or Device Instance in dc analysis of spectre...
  • Subscribers 132
  • Views 14685
In valid dev or Device Instance in dc analysis of spectre cadence
leonel1408
leonel1408 over 15 years ago
Invalid Component Name "DPS1.V0" was given as value of parameter!
Anyone who knows the proper ruling or naming convention for naming dev or device instance in dc analysis component parameter options in cadence spectre,.,. Thanks in Advance
    The correct naming convention is instName1.instName2.instName3 where the instance names are the names as they appear in the netlist - it's a hierarchical path down to the component you want to vary.
