  3. A summary of via types in my layout hierarchy
  • Views 17588
stuso
stuso over 15 years ago
Hi Guys, in IC6 is there a way to get a summary of all via types used in my layout, down the hierachy. I'm not interested in how many of each type is used i just want to know if its used.
Looks like the layout tree does not contain via info.
I'm thinking that i could stream to gds and then manipulate the PIPO.log to get via list or that i could use skill to identify the vias, but i just wondered if there is a faster or more elegent solution.
Cheers
Stu
  • skillUser
    skillUser over 15 years ago
     Hi Stu,
    You can look at the viaHeaders attribute, for example, at the top-level and get information that way, e.g.
    geGetEditCellView()~>viaHeaders~>master~>cellName
    => ("M2_M1" "M3_M2" "M4_M3" "M5_M4" "M6_M5")
    Hopefully this will help you in your task?
    Best regards,
    Lawrence.
    More direct is:
    cv~>vias~>viaHeader~>viaDefName
    If you want to collect this over a hierarchy, you'd need to do a recursive traversal of the design hierarchy (pretty simple to do).
    p, li { white-space: pre-wra
  • stuso
     Hi guys, do you mind if i enquire further regarding hierachy traversal. I have been trying to use the ccpExpandDesign for this:
    skipLibs=list("analogLib" "basic" )
    reflibs=gdmCreateSpecList()
        foreach( refLib skipLibs
          gdmAddSpecToSpecList(gdmCreateSpec(refLib "" "" "" "CDBA") reflibs)
    top_cell_gmmSpec=gdmCreateSpec("STU_LIB" "STU_TOP_CELL" "schematic" nil "CDBA")
    my_top=ccpExpandDesign( my_gdm 'CCP_EXPAND_COMANAGED reflibs  )
    which returns a warning:
    *WARNING* (ccpiTraverse) Illegal reentry!
    gdmSpecList:562139688
    Is this warning acceptable? If so how do i then manipulate "my_top" which appears to be a database object, does it somehow contain a list of my design hierachy cells?
    Many Thanks
    Stu
    Stu,
    my_gdm doesn't appear to be defined in the example above. I assume you meant to use top_cell_gmmSpec? I can find no information about this warning, but it sounds as if there is something suspect about your data - maybe you are indeed using the wrong variable?
    Just for completeness, here's an example of using these functions (although I'm not using the reflibs arg like you are). I did just try it myself on an example, and don't get the message you get.
    /* abNewLibraryRefs.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jan 12, 1999
    Modified   Feb 19, 2003
    By         A.D.Beckett
    Uses the new ccpExpand facilities to expand library data,
    either using the pc.db files (parent child databases),
    or using config files to find all the cellViews or libraries
    used. This is quicker than opening databases, and also supports
    configurations.
    Each of the four functions can be used externally.
    SCCS Info: @(#) abNewLibraryRefs.il 02/19/03.09:56:33 1.2
    *    (abNewCellViewRefs libName cellName viewName @optional     *
    *              (expandMode 'CCP_EXPAND_COMANAGED))              *
    *  Expand the specified cellView, returning a list of lists of  *
    *  cellView information. The expandMode is the keyword to pass  *
    *  to ccpExpand.* functions to say what files to include. The   *
    * default should be adequate for most cases. The expansion will *
    *   follow through the complete design hierarchy, into other    *
    *  libraries, since it uses the pc.db and config information.   *
    (procedure (abNewCellViewRefs libName cellName viewName @optional
      (let (spec expanded cellViews cellViewInfo obj)
           (setq obj (ddGetObj libName cellName viewName))
           (setq spec (gdmCreateSpecFromDDID obj))
           (setq expanded
                 (cond
                  ((ddGetObj libName cellName viewName "pc.db")
                   (ccpExpandDesign spec expandMode))
                  ((ddGetObj libName cellName viewName "expand.cfg")
                   (ccpExpandConfig spec expandMode))
                  (t
                   (setq specList (gdmCreateSpecList))
                   (gdmAddSpecToSpecList spec specList)
                   (ccpExpand specList expandMode))
           (gdmResetSpecList expanded)
           (while (setq spec (gdmNextFromSpecList expanded))
                  (when (and
                         (setq cellViewInfo (gdmInspectSpec spec "LibraryUnix"))
                         (equal (cadddr cellViewInfo) "master.tag"))
                        (rplacd (cddr cellViewInfo) nil)
                        (setq cellViews (cons cellViewInfo cellViews))
           cellViews
    *             (abNewLibraryRefs libName @optional sorted)             *
    *  Get all cellViews in a library, invoke abNewCellViewRefs on them,  *
    *     and then collate the information into a list of lists. The      *
    * optional argument is a flag to indicate that the information should *
    *                             be sorted.                              *
    (procedure (abNewLibraryRefs libName @optional sorted)
      (let (libObj cellViews cellViewTable)
           (unless
            (setq libObj (ddGetObj libName))
            (error "Could not open library %s\n" libName)
           /* create a table - easy way of removing duplicates */
           (setq cellViewTable (makeTable 'cellViewTable))
           /* visit all cells */
           (foreach cell (getq libObj cells)
                    /* visit all cellViews */
                    (foreach view (getq cell views)
                             /* get all the references, even through other libs */
                             (setq cellViews
                                   (abNewCellViewRefs
                                    libName (getq cell name) (getq view name)))
                             /* record any cellViews used in the table */
                             (foreach cellView cellViews
                                      (setarray cellViewTable cellView t))
           /* pull out everything from the table */
           (setq cellViews nil)
           (foreach cellView cellViewTable
                    (setq cellViews (cons cellView cellViews)))
           /* if sorted has been supplied and set to non-nil, sort the
              list before returning it */
           (when sorted
                 (setq cellViews
                       (sort cellViews
                             /* comparison function - sorts strings in lists */
                             (lambda (a b)
                                     (while (and
                                             (car a) (car b)
                                             (equal (car a) (car b)))
                                            (setq a (cdr a))
                                            (setq b (cdr b)))
                                     (and (car a) (car b)
                                          (alphalessp (car a) (car b)))
           cellViews
    *                      (abNewLibrariesUsed libName)                      *
    * Process the library, expand the design hierarchies and configurations, *
    *   and find out all the libraries referenced, directly or indirectly.   *
    (procedure (abNewLibrariesUsed libName)
      (let (libs)
           (foreach cellView (abNewLibraryRefs libName)
                    (unless (member (car cellView) libs)
                            (setq libs (cons (car cellView) libs))))
           libs
    *         (abNewLibrariesUsedByCellView libName cellName viewName)          *
    * Process the cellView, expanding the hierarchy, and find out all libraries *
    *                    referenced, directly or indirectly.                    *
    (procedure (abNewLibrariesUsedByCellView libName cellName viewName)
      (let (libs)
           (foreach cellView (abNewCellViewRefs libName cellName viewName)
           libs
