  3. How to run a scs file using ocean?
  • Views 15649
bobbygang
bobbygang over 15 years ago
    I can use command spectre in unix to run a scs file. But how can I achieve this in ocean?
I means that usually I set "simulator" "design" "analysis"  ...then I run an ocean.
But if I already had an input file, how to run it?
Best Regards,
Bobby
    Bobby,
    The design() function can be given the path to a netlist - but in this case the expectation is that this is a netlist without the analyses or models - just the actual design. Potentially it could be the complete file, but you'd have to jump through a few hoops to make it work. It might just be simpler to do:
    system("cd /path/to/netlist/dir; spectre -raw ../psf input.scs")
    or similar.
  • bobbygang
    Oh! It works! Thanks!
    Then if I add other command after system(), it  works after the system() completed, doesn't it?
    Yes.
