  3. A simple question how to modify pin shape
  • Views 19518
bobbygang
bobbygang over 15 years ago
   In symbol design,  I find that if I use "add pin" I can create a pin and I can specify its  type such as "squre" "round" "actHi". But how can I modify the type for existed pin of a symbol
 Best regards,
Bobby
  • linbo
    linbo over 15 years ago
     Hi Bobby,
    Did you want to change the actual shape of the pin or the type of the pin?  If you want to change the type, open your symbol for edit, select the pin and query the properties, usually the bindKey 'q'.  There's a cyclic field that has a list of all the pin types.
    If you want to change the shape you'll need to delete the old pin and create a new pin using the Create->Custom Pin... command from the symbol's menu banner.
    Hope that helps...
  • bobbygang
    Hi linbo,
           I'm afraid actual shape is the thing I want.   So you mean there is no method to modify existed pin shape? I have a lot of pins to modify, delete and create will take too much time.
    Best regards,
    Bobby
  • linbo
     Hi Bobby,
     You could write a skill routine to do this.  Perhaps some kind soul on this forum might write one for you.
     --lin
