  3. Monte carlo results access through ocean
  • Views 15373
SUHAS G
SUHAS G over 15 years ago
hi all,
i am running monte carlo on a simple inverter, i have made changes in the netlist and run the command "spectre input.scs" from the respective netlist folder. Monte carlo results are generated. input.raw file has all the simulation results. all i want to know is, how do i access these results through an ocean script?  or Can i dump the results to a text file directly by making changes in netlist?
modified netlist is as shown below,
f// Generated for: spectre
// Generated on: Jun  2 12:02:20 2011
// Design library name: Tower_work_SG
// Design cell name: TEST_INVERTER
simulator lang=spectre
global 0
include "/tools/Tower/TS18SL_DF2/HOTCODE/amslibs/cds_default/cdslibs/ts18sl/models/default/spectre"
parameters AVDD=5
include "/tools/Tower/TS18SL_DF2/HOTCODE/amslibs/cds_default/cdslibs/ts18sl/models/default/spectre/global.scs" section=GLOBAL
include "/tools/Tower/TS18SL_DF2/HOTCODE/amslibs/cds_default/cdslibs/ts18sl/models/default/spectre/fet.scs" section=NOM
include "/tools/Tower/TS18SL_DF2/HOTCODE/amslibs/cds_default/cdslibs/ts18sl/models/default/spectre/bjt.scs" section=NOM
include "/tools/Tower/TS18SL_DF2/HOTCODE/amslibs/cds_default/cdslibs/ts18sl/models/default/spectre/accap.scs" section=NOM
include "/tools/Tower/TS18SL_DF2/HOTCODE/amslibs/cds_default/cdslibs/ts18sl/models/default/spectre/mimcap.scs" section=NOM
include "/tools/Tower/TS18SL_DF2/HOTCODE/amslibs/cds_default/cdslibs/ts18sl/models/default/spectre/mfc.scs" section=NOM
include "/tools/Tower/TS18SL_DF2/HOTCODE/amslibs/cds_default/cdslibs/ts18sl/models/default/spectre/res.scs" section=NOM
include "/tools/Tower/TS18SL_DF2/HOTCODE/amslibs/cds_default/cdslibs/ts18sl/models/default/spectre/diode.scs" section=NOM
// Library name: Tower_work_SG
// Cell name: TEST_INVERTER
// View name: schematic
V0 (Vin 0) vsource dc=0 type=pulse val0=0 val1=5 period=100n delay=0 \
        rise=100p fall=100p width=50n
C0 (OUT 0) capacitor c=50f
V1 (net5 0) vsource dc=AVDD type=dc
parameters x=0
subckt  xn5v dn gn sn bn
parameters lx=1.0  wx=12.0 ad=0 as=0 pd=0 ps=0 mx=1
M0 (dn gn sn bn) n5v w=wx l=lx ad=1.44 \
        as=1.44 pd=6.96 ps=6.96 m=(1)*(1)
+delvto= (x*10e-03/sqrt(lx*wx*mx*1e12))
ends xn5v
subckt  xp5v dp gp sp bp
M1 (dp gp sp bp) p5v w=12.0 l=1.0 ad=3.84 \
        as=3.84 pd=16.96 ps=16.96 m=(1)*(1)
ends xp5v
I1 (OUT Vin 0 0) xn5v
I2 (OUT Vin net5 net5) xp5v
//M1 (OUT Vin net5 net5) p5v w=8.0 l=1.0 as=3.84 ad=3.84 ps=16.96 pd=16.96 \
 //       m=(1)*(1)
//M0 (OUT Vin 0 0) n5v w=3.0 l=1.0 as=1.44 ad=1.44 ps=6.96 pd=6.96 m=(1)*(1)
mc1 montecarlo variations= mismatch seed =1234 numruns=20 savefamilyplots = yes saveprocessparams=yes
+scalarfile= "mcdata"
+paramfile= "mcparam"
+processparamfile="processParam"
+processscalarfile="processData"
dc1 dc
tran1 tran stop= 1u
export mid = oceanEval ( "peakToPeak(v(\"OUT\")) /2")
export t1 = oceanEval ("cross(v(\"OUT\") mid 1 'rising)")
export t2 =oceanEval ("cross(v(\"OUT\") mid 1 'falling)")
export t3 =oceanEval ("cross(v(\"OUT\") mid 2 'rising)")
export on_time =oceanEval ("t2-t1")
export period  =  oceanEval ("t3-t1")
export duty_ratio = oceanEval("(on_time/period) *100")
statistics {
      mismatch {
            vary x dist= gauss std =1 percent=no
save x
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
    tnom=27 scalem=1.0 scale=1e-06 gmin=1e-12 rforce=1 maxnotes=5 \
    maxwarns=5 digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output" \
    checklimitdest=psf
tranCheckLimit checklimit checkallasserts=yes severity=none
tran tran stop=1u errpreset=moderate write="spectre.ic" \
    writefinal="spectre.fc" annotate=status maxiters=5
dcOpCheckLimit checklimit checkallasserts=yes severity=none
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
subckts info what=subckts  where=rawfile
asserts info what=assert  where=rawfile
save OUT
saveOptions options save=allpub subcktprobelvl=2
thanks in advance.
Suhas
    The results are directly available in the ASCII files mcdata and mcparams. You can also use the code in this solution http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11026072 to post-process the results from OCEAN.
