  3. Config view and ADE-XL
  • Views 15381
frogconsultant
frogconsultant over 15 years ago
My current environment under ADE-XL is as follow I have create a cellName called counter and a cellName called counter_tb to test it. This counter has a veriloga view as well as a schematic view. So I have created a config view for the cellName counter_tb in order to be able to switch between schematic and veriloga view of the counter in between two simulation.
Under ADE-XL, I setup a test using the config view of the cellName counter_tb. I am running the first simulation and then I switch view and I am running the second simulation. I could tag the results with the proper conditions. My questions are the following:
How could I link the config details and the results run in case I have not tag the results and it is call Interactive.X?
Is it possible to load somehow this config setup used during a specific run in order to check the configuration?
Thanks in advance,
Fabian
