  3. changing the Result directory in ADE XL
  • Replies 7
  • Subscribers 133
  • Views 24225
archive over 15 years ago
Hi ,
I am new to ADE XL and tried to change the Result directory to the local path can someone please let me know how to do that ?
i tried the following stuff Option->Save->(check the option)Use Locan Simulation Result Directory
but somehow i do not know where the PSf file is being written
Ankur
  • MaK78
    MaK78 over 15 years ago
    You should define result directory location and result database location in "Options -> Save " under "Simulation Results Directory Location" and "ADEXL results Database Location".
    Hi Marc,
    Thanks for the answer
    Can they all point to the same directory ?
    Thanks & Regards,
    Ankur Gupta
  • MaK78
    Yes.
     Mahmood
    Generally I would advise leaving the "ADE XL Results Database" location blank, as this means it will be stored within the ADE XL view itself. This is relatively small, and contains the scalar result information from any measurements - and can be revisioned along with the rest of the ADE XL setup and history.
    The Simulation Results data is much larger, and it's usually that which you would want to move elsewhere.
  • MaK78
    Thanks Andrew for the correction.
    Hi ,
    I changed the result directory as suggested in ADEXL. but unfortunately when i run a RCX Simulation (only incase of RCX simulation) i get a lot of warnings in the CIW window
    WARNING (OCN-6040) : The specified firectory does not exist , or the directory does not contain valid PSF results. Ensure that the path to the directory is correct and the directory gas a logFile and PSF result files.
    What i do not undestand is why it searches for PSF data when it has still not started simulating. since the path exist on the network may be its not able to access it ?? but then why only incase of RCX simulations
    Ankur
    Ankur
    Please contact Cadence Customer Support about this.
