  3. Parametric Analysis with two sources (DC) in ADE
  • Views 7404
StreamCX
StreamCX over 15 years ago
I have two DC sources.
I load ADE. Choose DC analysis, select component name. I can do DC analysis with one DC source.
How can i do this with two?
    Tools->Parametric Analysis?
  • StreamCX
    How can I output the result in param analysis the best way?
    Tools/Result browser?
    In Result browser alta variable  displays discrete, altb variable displays conitniously. I want see them discrete both.
    But I want to see signals from another wire which is not of param swept variable.
  • StreamCX
     setup/add new variable to top?
    When I try output graph nothing appears.
  • fomin
    fomin over 15 years ago
    You can use alta as DC sweeping parameter and altb as a variable of Parametric Analysis. When you plot a result it should be looks like several DC plots each one for different variable value.
