  3. simulating pulse width variation
  • Views 17549
svilen
svilen over 15 years ago
I have a circuit that basically produces pulses with a pulse width depending on a control voltage. I use spectre to simulate it. I need to simulate the variation of the pulse width w.r.t. power supply variations. My idea was (and I may be wrong here) to perform pss-pac simulation having an ac voltage at the supply. For that I created a veriloga block which I included in the circuit. That block measures the pulse-width and outputs that value as an output voltage. The problem is that if I use last_crossing in combination with @ cross for better accuracy, pss doesn't like it and says there are hidden states. If I use only last_crossing then simulation goes through but the pulse-width the pss extracts is wrong.
I would appreciate if someone can suggest a way to perform that pulse-width measurement.
Thank you in advance.
    A couple of thoughts. First of all seeing the code would help, because there's no reason why @cross necessarily causes a hidden state problem - it depends what you do inside the @cross.
    Anyway though, the pss result would not change dependent on the ac source - this is because the PSS is only done on the large signal conditions - and so the small signal would not impact the PSS results.
  • svilen
    Andrew, tanks for the reply. Here is that part of the veriloga code that performs the pw measurement:
      tr=last_crossing( V(pw_dac)-V(vdda09)/2, 1);  // time of the rising edge of charge
      @ ( cross( V(pw_dac)-V(vdda09)/2,1 ) ) begin
        crossing=crossing+1;
      end
      tf=last_crossing( V(pw_dac)-V(vdda09)/2,-1);   // time of the falling edge of charge
      @ ( cross( V(pw_dac)-V(vdda09)/2,-1) ) begin
           if (crossing  == 4 ) begin
            chrg_pw=tf-tr;    // find charge pulse-width
            $fstrobe(pw_file, "%-.4g", chrg_pw);
          end
      end
      V(pulse_width) <+ transition(chrg_pw, 0, 100p);
    Do you have any suggestion how to measure the pulse-width variation caused by variations in th epower supply?
