  3. Segmentation Fault on Solaris 10/sparc while using IC61...
  • Views 1677
Segmentation Fault on Solaris 10/sparc while using IC613
upengan
upengan over 15 years ago
 virtuoso -W
sub-version IC6.1.3.500.19
 uname -a
SunOS hostname 5.10 Generic_142909-17 sun4u sparc SUNW,Sun-Fire-V440
 If I run' virtuoso ' GUI Window opens and closes immediately and screen shows Segmentation fault.
CDS.log
\o Program:             @(#)$CDS: virtuoso version 6.1.3 05/19/2010 06:07 (cic612sun) $
\o Hierarchy:           /import/app8/cadence2011/IC613/tools.sun4v/dfII/
\o Sub version:         sub-version IC6.1.3.500.19 (32-bit addresses)
\o Host name (type):    servername (sun4u)
\o Operating system:    SunOS 5.10 Generic_142909-17
\o X display name (WxH):        localhost:15.0 (1280x1024)
\o Available geometry:                  TL(0:0) BR(1279:999)
\o X server:            The X.Org Foundation
\o Depth of Visual (Root):      24 (24)
\o Number of Planes Used:       24
\o X version:           11.0 (vendor release 11002000)
\o X resource pool:     base 0x2400000, mask 0x1fffff (2097151), shift 0
\o                      current id 0x4c, current max 0x1ffffa (2097146)
\o Qt version:          4.2.3
\o Window Manager:      other
\o User Name:           username
\o Working Directory:   servername:/home/username/hjlee
\o Process Id:          10712
\o
\o COPYRIGHT � 1992-2009  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
\o           � 1992-2009  UNIX SYSTEMS Laboratories INC.,
\o                          Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
checkSysConf IC6.1 --noDISPLAY
[Copyright 2002-2008]   Cadence Design Systems, Inc. All rights reserved.
This  program and online  documentation  may not be copied, modified,
re-published, uploaded,  executed, or  distributed in any way, in any
medium, whether in whole or in part, without prior written permission
from Cadence Design Systems, Inc.
============== checkSysConf:  Version 1.46 ====================
Date information gathered: Tue Jun 28 10:38:19 CDT 2011
Host Name ..............:  servername
Hostid .................:  8333754d
Operating System .......:  SunOS / sun4u
OS Version .............:  5.10
Hardware Type ..........:  Sun-Fire-V440
Memory .................:  16384 Megabyte
No. of CPUs ............:  4
Total Swap Space........:  8193 Megabyte
Graphics ...............:  UNKNOWN
Patch Data file ........:  /import/app8/cadence2011/IC613/share/patchData/SunOS/sparc/5.10/IC6.1
****************   Now verifying configuration     ****************
Creating the OBSOLETE file.
Validating MEMORY requirements in MegaByte ...
                    Minimum   Installed Status  Info
                    128   MB  16384 MB  PASS
Validating SWAP requirements in MegaByte ...
                    200   MB  8193  MB  PASS
Validating DISPLAY requirements...
#  Minimum       Installed     Status      Info
                    TEST SKIPPED BY USER!              NOT TESTED
Validating PACKAGE requirements.....2 to check
                    Package   Installed Status  Info
                    SUNWi1of  SUNWi1of  PASS
                    SUNWgnome-base-libsSUNWgnome-base-libsPASS
Validating GRAPHIC-PATCH requirements.....0 to check
Validating HARDWARE requirements.....0 to check
Validating LOCALE requirements.....0 to check
Validating PATCH requirements.....7 to check
#   PATCH     Min   Installed   Status  Info
1   119059    20    56          PASS
              Xsun patch
2   118833    33    36          PASS
              kernel patch
3   119963    07    21          PASS
              C++ shared library Patch
4   120753    03    07          PASS
              Microtasking libraries Patch
5   118676    03    03          PASS
              Patch for make and sccs utilities
6   118683    01    04          PASS
              Patch for assembler
7   120812    12    31          PASS
              OpenGL Patch for Solaris 10
Validating NOT-PATCH requirements.....0 to check
Validating FILE existence .....0 to check
Validating NOTFILE existence .....0 to check
Normal exit. This workstation (servername) status is: PASS
Exiting checkSysConf ... Good-bye
Output is saved as /tmp/checkSysConf.servername-2011.06.28.10:38.log
  • upengan
     Issue was resolved. It was /etc/nssswitch.conf that was the problem. Cadence support was notified about my solution. Thanks
    This might be the same as CCR 758990 which was actually to do with the licensing code from Flexera. Or it might be something else.
    The best thing to do is contact customer support. However, before that you might want to consider trying a more recent version (e.g. IC615 ISR4 or IC614 latest ISR).
