  3. Negative cbb (Bulk Capacitance) in BSIM4
  • Views 15629
ckchua
ckchua over 15 years ago
Hi, We are currently having problem with transient convergence on a particular circuit. Checking with the developer reveals that certain transistors in the circuit had negative cbb which causes this convergence issue. They are now trying to get us to confirm that this cbb parameter cannot be a negative value. Anyone has any idea on this? Thank you in advance.
    It's perfectly reasonable for these to be negative. They're actually partial derivatives in bsim3v3 and bsim4 - see Solution 1814346
  • ckchua
    Hi Andrew, Thank you so much for your reply. I think this would help a lot.
