  3. *Error* eval: code size too big inside a construct (32767...
  • Views 16203
*Error* eval: code size too big inside a construct (32767 max; 32771 given)!
Jameel
Jameel over 15 years ago
I have a simple skill script as below
load("co_ord_list.il")
foreach( crd_inst crd_list
       dbCreateInstByMasterName(cvid  src_lib  src_cell  "layout"  nil crd_inst "R0" 1)
 );end foreach
the co_ord_list.il is a simple file that creates a variable called crd_list  whis is a list of co-ordinates like code below.
crd_list = list(
  list( -60770.0 73220.0 )
  list( -56650.0 73220.0 )
  list( -54590.0 73220.0 )
  list( -52530.0 73220.0 )
  list( -50470.0 73220.0 )
  list( -48410.0 73220.0 )
  list( -46350.0 73220.0 )
The problem is I have a huge number of co-ordinates ~200,000 pairs and I get  *Error* eval: code size too big inside a construct (32767 max; 32771 given)!
I can work around the problem by splitting the  co_ord_list.il into smaller chunks but it was wondering if there is any simpler solution.
-Jameel
  • skillUser
    skillUser over 15 years ago
    Hi Jameel,
    You are probably hitting one of two limitations; there is a maximum size (code vector) for SKILL in terms of lines per procedure, let, or presumably in this case lines within your list assignment, or another limitation is the number of points that a single polygon can have. So it is probably necessary to split the points into smaller lists for these two reasons. Not much help I know, but I believe this is the answer.
    Lawrence.
  • Jameel
    Hi Lawrence,
    The co-ordinates are not point on a polygon but points where instances are placed. So I think I am exceeding the code vector.
    I guess splitting the code into smaller chunks is my bet bet.
    Thanks.
    -Jameel
  • skillUser
    Hi Jameel,
    I think so, and sorry for not reading your code properly, I should have read it more thoroughly :-)  So you should still be able to put all the points in one file, perhaps just use one or more new variables for storage. You can programmatically iterate over the variables too, you might use something like the following:
    foreach(var listVariables("^var[0-9]*")
      foreach(ptsPair symeval(var)
        ;; ... code as before
      ); foreach co-ordinate pair
    ); foreach variable that stores coordinates
    The listVariables function allows you to match the variables by name and then iterate over those found, making the solution more automated.
    Lawrence.
    Lawrence, Jameel
    That (the listVariables approach) is a horrible way to do it (sorry) - it relies on knowing the names of global variables. Very bad practice.
    Far better is to change the file contents and not use load to load it. If the file looked like this:
    Then you could do:
    prt=infile("co_ord_list.txt")
    crd_list=car(lineread(prt))
    close(prt)
    This will slurp in the entire list into the variable in one go, and it's not then code and so no code vector to worry about. It's just data. Also this should be faster, as you do not have to call list() many many times (that's probably a small benefit though).
    The advantage is that lineread is using the SKILL parser, so provided it follows SKILL syntax, it's easy to read. The reason for the car is because lineread returns a list of the things read - you could have multiple entries on the same line - and in this case we're only interested in the first thing on the first line (well, it covers multiple lines, but it starts on the first line).
  • Jameel
     Andrew, Thanks as always :)
