  3. How conver libraries from 5141 to 6.1 Cadence
  • Views 6438
TiNat
TiNat over 15 years ago
Hello. I earlier used Cadence 5141, but now I need to use Cadence 6.1. Who can help me, how do quickly convert all my schematic libraries to new version? What tool can I use? I have library with circuit and library with schematic elements. Thank you for your help.
  • Marc Heise
    Marc Heise over 15 years ago
    I would recommend reading carefully the adoption/migration guides available in the 6.1 documentation. They explain the
    cdb2oa translator and all the things you should look for.
    Marc
  • TiNat
    Thank you very much. I have result,but at first I have a lot of problems. By trial and error I have decided task.
  • skillUser
    skillUser over 15 years ago
    There is a flow based guide to migration and translation to the IC61x OA database from the IC5141 CDBA database on the Support website. This contains a detailed step-by-step breakdown of the tasks involved in moving to IC6.1
    Hopefully you and others will find this useful information.
    Lawrence.
