  3. DRC License Error
  • Views 17168
DRC License Error
legolas
legolas over 15 years ago
 I am getting the following error when I attempt a Verify->DRC with Cadence Virtuoso 6.1.4:
*WARNING* No DRC (Assura_DV_design_rule_checker) or DRC (312) license is available
*WARNING* Verification program terminated
 Basically, I wish to use the divaDRC.rul for DRC.
 Please provide inputs.
    The message is prettty clear - you don't have a Diva license! (either you don't have one, or they're al in use).
  • sreejisg
    sreejisg over 8 years ago
    Which tool is required to run DRC ?
    Cadence offer several:
    • Pegasus (latest generation - essentially the successor to PVS) - currently only for advanced nodes with limited partners
    • PVS (Physical Verification System) - mainstream tool
    • Assura - needed for some older technologies
    • Diva - legacy physical verification tool
    • Dracula - still used by some older processes
    There are also some tools from companies other than Cadence. Generally speaking you need to find out what is supported by the foundry you're using - depending on the technology, they provide decks for specific tools.
