  3. Gaussian distributed variables
  • Views 18391
Malolo
Malolo over 14 years ago
My circuit has 3 vaiables that are independent and follow gaussian distribution, I have 1-sigma values of them respectively and woud like to apply the distribution to them. The ideal scenario for me would be running 100 runs and each time these 3 variables take different values but follows gaussian distribution indepently.How can this be done in Cadence ADE? i'm using ic 5141, simulator is spectre.  btw, i dont have mc model file for this.
thanks a lot!,
Malolo
    Malolo,
    You'll need to create a statistics block defining the variation of these parameters in a file, e.g. stats.scs :
    statistics {
      process {
        vary param1 dist=gauss std=5
        vary param2 dist=gauss std=1.2
    then in ADE define these two variables as design variables, and the value of them will set the mean. Reference the above file via Setup->Model Libraries. Then use the variables on components in your design.
    Having done that you can run monte carlo with 100 runs, and you'll get the variation.
  • Malolo
     Thanks a lot, Andrew.
    Malolo
