  3. skill - write a file with skill variables
  • Replies 8
  • Views 7511
ejm20
ejm20 over 14 years ago
In skill, how do you create a file and overwrite if its present with the contents that are skill variables?  Heres a snipet of the the code to get produce the variables:
      tool_opt=testSession~>simID~>data~>env~>data~>turboOpts~>data~>uniMode~>value
         println( tool_opt )
      rcReduction_opt=testSession~>simID~>data~>env~>data~>turboOpts~>data~>psrSwitch~>value
         println( rcReduction_opt )
      println( mt_opt )
 The evaluated variables will then be written into a file named "myFile"  .   As an example:
tool_opt   =  spectre
rcReduction = nil
mt_opt  =  Disable
 so......
spectre nil Disable
  • ejm20
    this seems to work
        myPort = outfile( "runSimulation" )
        fprintf(myPort "%s %s %s" tool_opt  multiThread  paraReduction )
        close(myPort)
  • skillUser
    skillUser over 14 years ago
    One thing that I would add is that this is fine if you are sure that the variables are all strings, but if not then it may be better to use "%L" for each of the format specifiers - if the variable was not a string then the %s format would cause fprintf (or sprintf or printf) to choke and fail, but %L can be used for any value, 'nil', a list, an integer, a floating point number etc.  You can use the "type" function to obtain the type of a variable, or individual predicate functions like "stringp", "listp" etc. to programmatically test and avoid such an issue also.  E.g.
    if(forall(var list(tool_opt multiThread paraReduction) stringp(var)) then
      ;; print variables out nicely if they are all strings
      fprintf(myPort "%s %s %s\n" tool_opt  multiThread  paraReduction )
    else
      ;; print values out using default %L format if they are not all strings
      fprintf(myPort "%L %L %L\n" tool_opt  multiThread  paraReduction )
    You could even build the format string based on the variable data type (that seems overkill here).
    Lawrence.
    And you're still accessing internal data structures rather than using the API intended for providing procedural abstraction, as I explained about in your previous post.
    Best Regards,
  • ejm20
    I was not able to get the  api  functions to work
  • ejm20
    Thanks for the tip!
    Well, there must have been something wrong in your code, because it works. I would definitely avoid what you're doing, because if something changes in the internal data structures, your code will break. Here's what I had:
    procedure(myPreRun(session sdb mode test)
      let((tests testSession asiSession mtOption uniMode psrSwitch)
        tests=axlGetTests(sdb)
        foreach(testName cadr(tests)
          if(axlGetEnabled(axlGetTest(sdb testName)) then
            printf("test %s is enabled\n" testName)
            testSession=axlGetToolSession(session testName)
            asiSession=sevEnvironment(testSession)
            printf("testSession: %L asiSession: %L\n" testSession asiSession)
            mtOption=asiEnvGetVal(asiSession "turboOpts" "mtOption")
            uniMode=asiEnvGetVal(asiSession "turboOpts" "uniMode")
            psrSwitch=asiEnvGetVal(asiSession "turboOpts" "psrSwitch")
            printf("High perf options: MT: %L uniMode: %L paraRed: %L\n"
      t
    ; axlSessionDisconnect(sess 'myPreRun)
    ; axlSessionConnect(sess "preRun" 'myPreRun)
  • ejm20
    Is the "t" above the 2 ")"  correct?
    Yes.
    That said, it's not that important - I was just making the function have a simple, well-defined, return value (t means "true" in SKILL); without this it would have returned the return value of the foreach, which is the list it is iterating over.
    You can miss out the t if you want.
