  3. Calibre interactive falis to export schematic netlist from...
  • Subscribers 133
  • Views 16562
Calibre interactive falis to export schematic netlist from Virtuoso 6.1.5
eggzhang
eggzhang over 14 years ago
Currently I met with a problem during Calibre LVS. Calibre interactive falis to export schematic netlist from Virtuoso 6.1.5.
Then I tried to use 'File/Export/CDL' from Virtuoso. Again, it failed. The si.log message is similar to the failure information I got from Calibre LVS run. It is as follows:
 Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.11s.
*Error* ilGetValue: nil argument, must be a symbol
******* Non-recoverable error (no top-level or error handler)
******* Exiting program ...
*WARNING* (icLic-3) Could not get license Virtuoso_Schematic_Editor_L
 What's the problem?
Thanks a lot!
Dai
    Dai,
    This is covered in Cadence Online Support Solution 11698172
    It's fixed in IC615 ISR1 (so the first hotfix) and is workaroundable by putting:
    license VSELicenseCheckoutOrder    string "XL,L"
    in your ~/.cdsenv file. Having this set with an envSetVal() in the .cdsinit doesn't help, because the "si" program used for CDL netlisting doesn't read the .cdsinit. The problem only occurs if you only have Schematic XL licenses (and no Schematic L licenses).
