  3. Specifying an include file on schematic
  • Views 16562
swdesigner
swdesigner over 15 years ago
My end goal is to get a netlist I don't need to touch. Is it possible to create an schematic_RCX view for a cell (regular schematic view) and add a component to that schematic which specifies a file to include in the netlist for that cell?
For example, when the netlist for the cell is created, the file will look like :
subckt block_name ....
// normal component lines
include "/path/to/user/specified/file"
ends block_name
// other component lines
Since there are components like PWL waveforms that can read files, this is of course feasible, but is it already available/easy is what I'm really after...
Thanks!!
  • swdesigner
    Seems to be a solved problem :
    Soution ID : 11015428
    I haven't verified yet...
    Ah, one of mine!
  • chqian
    chqian over 7 years ago
    Can you tell me how you solve the ?
    Andrew Beckett over 7 years ago in reply to chqian
    I already mentioned the article number on the support site above - in your other post my colleague Marc added a link to the same article.
  • chqian
    chqian over 7 years ago in reply to Andrew Beckett
    Thanks a lot.Andrew
