  3. spiceIn bjt
  • Views 16772
spiceIn bjt
mhowell67
mhowell67 over 14 years ago
Using virtuoso 6.1.4 and trying to import a CDL with the spiceIn utility.
 I get the following error returned in the log:
    Instance: Q156
    Instance has master: 'bjt' model/subtype: 'XP'
        Master Cell: 'bjt'.
        Did not find 'CMOS.bjt:symbol'.
ERROR (SPICEIN-24): Spice In did not find the symbol view of the master cell 'bjt' of the instance
'Q156' in the subcircuit 'amos_c14bg0v9'. Specify the reference library that has the symbol
view of the master cell, or use device-mapping to map 'bjt' to a different
cell.
I am using a device map file to map bjt to pnpv. This is the syntax in my map file.
devSelect := bjt pnpv
    propMatch := XP
    termOrder := C B E
    propMap := EA ae
The pnpv cell exist in CMOS library but spiceIn does not find it.
 What am I doing wrong?
  • Quek
    Quek over 14 years ago
    Hi mhowell67
    Would you please post the line in cdl netlist for Q156?
    Quek
  • mhowell67
     Q156 gnda gnda n32 XP $EA=16
     I actually got the SpiceIn t work.  I modified the mapping to read as follows;
        propMatch := Subtype XP
        termOrder := C B E
        propMap := EA ae
    Another work-around before I got the mapping to work was to copy pnpv cell into a dummy library, rename it bjt, and add the dummy library to my library reference list in spiceIn.
  • Quek
    Hi mhowell67
    Thanks for the reply. It is good to know that you have resolved the problem. : )
    Best regards
    Quek
