  3. incorrect extraction issue
  • Replies 19
  • Subscribers 133
  • Views 34224
kristen
kristen over 14 years ago
I am working with Virtuoso version IC6.1.3.500.13 and mentor 2011 (also have access to older versions and have previously used 2009). The pdk I am working with apparently has a known bug (confirmed by the foundry) such that the extracted transistors are always incorrect - instead of a 10 finger fet with total width 8um, for example, the tool extracts 10 transistors, 1 finger each, EACH with a width of 8 um. does anyone have any suggestions on how to manually fix this so i can run simulations on the extracted circuits using the config view? I have tried 1. manually editing the calibre view to ensure the correct width for each fet - i then get the error Error (OSSHNL-109) : the cell view, [name of calibre view], has been modified since the extraction. Re-extract the design (File->Check and Save menu option) for schematic cell views to correct this error. 2. copying and pasting extracted circuit to a schematic view - i then get the error ERROR (ADE-6026): Unable to create the netlist due to failure of the following operating system command "cat: ihnl/cds1/netlist: No such file or directory". Thanks.
  • Quek
    Quek over 14 years ago
    Hi Kristen
    Your setup looks good and it looks like the cell has been netlisted correctly. It is really strange. By the way, may I know the version of spectre which you are using?
    terminal>spectre -W
    Quek
  • kristen
    Quek - the version is 7.1.1.169.isr10. thanks again for all your help.
  • Quek
    Hi Kristen
    Sorry that I am not sure where the problem is. I think it should be just a setup problem because this really cannot be too difficult but it would take a good examination of the actual setup to determine the cause of the problem. I would suggest filing a service request with your nearest Cadence support centre and let an engineer assist you on this. : )
    Best regards
    Quek
  • kristen
    Hi Quek-
    thanks, I have been trying to get some support from Cadence directly but so far have not heard anything. I had one last idea i wanted to try, making a completely new symbol/spectre object (following your instructions precisely) and then instead used a new .scs file (all with the consistent name "test" that consists of the following very simple netlist:
    simulator lang=spectre
    subckt \test (MYGND VBIAS OUT VIN)
    R1 (VBIAS MYGND) resistor r=10k
    R2 (VIN MYGND) resistor r=1k
    R3 (OUT MYGND) resistor r=100
    ends \test
    Now I get a new error, that says:
    An instance of 'test' can have at most 4 terminals (but have 0).
    in the netlist, the line reference the spectre block is just
    I0 test
    wtih no pins being populated.
    any thoughts on this?
  • Quek
    Hi Kristen
    This is most likely due to missing termOrder info in CDF. Would you please check if CDF simInfo for "test" cell is as shown below?
    Best regards
    Quek
  • kristen
    Quek-
    thanks, it works now (i had forgotten the parentheses).
    after copying and pasting the old .scs file into this test.scs file the simulations now run. maybe there was some syntax issue with the old file name.
    Thanks again.
  • Quek
    Hi Kristen
    Just to resolve the mystery completely, would you please help to execute the following cmd on the original scs file and let us know the output? Thanks.
    linux>file yourfile.scs
    Best regards
    Quek
  • kristen
    Hi quek - the result is "yourfile.scs: ASCII C++ program text".
  • Quek
    Hi Kristen
    Thanks. I thought that there might be ^M characters in the file that is causing the problem. Looks like it might not be the case. Anyway, you can still try running it through "dos2unix" command to see if it makes a difference. : )
    Best regards
    Quek
