  3. cadence Calibre xRC extraction
  • Views 17380
whlinfei
whlinfei over 14 years ago
Hi all, i am using Calibre 2010.2_13.12 to do the post layout extraction. under PEX optioins-database-Precison, there are two numbers to specify precision and resolution. there are no units given for these two number. Can anyone help to interpret the meaning of these two ? Also, when doing xRC extraction, what are the things that should be set to get a accurate results? Thanks. in advance. Best Regards, Linfei
    Your post title says "cadence Calibre xRC extraction". Well, Calibre is a tool from Mentor Graphics, not Cadence. Whilst somebody on this forum may well know the answer, you would probably be better off posting this in an equivalent forum on their site (or log a support request with Mentor).
