  3. Auto Checkout Preferences
  • Subscribers 136
  • Views 19886
ForcedToWork
ForcedToWork over 15 years ago
 I'm looking for the command to get auto checkout set to "always ask me" as a default for cellviews and also files/properties.  The log  has:
ddsCheckoutPrefForm->prefAskCVs->value="always ask me"
after changing the value manually. I've tried a few things, like CDS_PROMPT_CKOUT and variations of the line above, but haven't hit the correct structure yet.
This is in IC6.1.4.500, layout view.
Is there a location to cross reference commands or another way of determining to correct Cadence command?
    Before starting virtuoso, this would be:
    setenv CDS_AUTO_CKOUT all
    setenv CDS_PROMPT_CKOUT all
    This is actually the default though. The SKILL equivalent (which will win over the env vars) is:
      ddAutoCtlSetVars(3 3 3 3)
    that's setting the checkin vars too - the default would be:
      ddAutoCtlSetVars(3 2 3 2)
    maybe you have something in your environment which is already calling this? ddAutoCtlGetVars() retrieves the current setting.
  • ForcedToWork
     Perfect.  Added it to cdsinit to overwrite the env.
  • sfgiantsfan
    sfgiantsfan over 11 years ago
    what is last two digits do? I tried changing last two and notices no changes as long as first two digits are remained same.
    In Virtuoso, do Help->Virtuoso Documentation Library (or run `cds_root virtuoso`/tools/bin/cdnshelp from the command line) and ensure that the Documentation Browser is shown (View->Show Navigation if it's not there). Then type in ddAutoCtlSetVars in the search box.
