  3. CDB to OA library conversion: cdb2oail error
  • Views 15270
ASICnm
ASICnm over 14 years ago
We are trying to port our design libraries from CDB to OA using the cdb2oa script. Our CDB libraries use the ST Microelectronics cmos065_522-2 technology library. The converted OA libraries also use the cmos065_522-2 library. When we execute cdb2oa we get the following error message in the log file
ERROR   (CDBOA-126): cdb2oail error: "exec of '/sw/cadence/ASSURA-615/tools/dfII/bin/cdb2oail' failed with exit status 127."
We are unable to find the cause of this error. Could you please guide us to diagnose the error ? What will be the consequences on the converted libraries (in OA) ?
We are using IC 6.15.
    I believe you have $ASSURAHOME/tools/dfII/bin in your path - whereas it should just be $ASSURAHOME/tools/bin - there's no need for the tools/dfII/bin part.
    Because of that, there's a mix up in the versions being picked - particularly because of the fact that (most likely) you have ASSURA before the IC paths.
    Can you try altering your UNIX $PATH to see if that solves the problem?
