  3. Assura LVL doesn't flag text
  • Subscribers 133
  • Views 804
Anonymous
Anonymous over 14 years ago
Is there a switch to flag labels that aren't the same? I found a label (through lvs) that was on PIN layer instead of DRAWING. It wasn't flagged as a difference, and in the future it would be nice to avoid this. Thanks! Rob
  • Quek
    Quek over 14 years ago
    Hi Rob
    Unfortunately, there is no such switch. In the automatically generated Assura LVL rules file, geomXor only accepts polygon inputs, not text inputs. Hence it is not possible to compare text. You can try dumping both layouts to gds ascii format and use gvim or any other editors to do a diff.
    Best regards
    Quek
