  3. How to define double vias in rules file for VCAR
  • Replies 12
  • Views 23258
PSRK
PSRK over 15 years ago
 I'm using the below constraint in the vcar rules file  before exporting. The VCAR is placing single via while routing.
    list( '("tsmc18rf" "M2_M1" "symbolic") t)
But I dont know the rule to keep double contact/via in the router .Please help me.
Siva
  • PSRK
    PSRK over 14 years ago
    Peter,
    You don't Have to worry about the rules file. Anyways, you can still use the commands in my earlier comments in your do file. or you can just type in the commands in the autorouter console before you execute route command.
    FYI,
    You can attach the files in here if you click the "options" botton next to the compose botton
    Siva
    What you should be able to do is define inside virtuoso which vias you wish to use by creating a constraint group and defining the allowable vias. That can be done in the constraint manager in VLS-XL.
    If anything is unclear though, the best thing to do is to go to customer support.
