  3. How to define double vias in rules file for VCAR
  • Replies 12
  • Views 23256
PSRK
PSRK over 15 years ago
 I'm using the below constraint in the vcar rules file  before exporting. The VCAR is placing single via while routing.
    list( '("tsmc18rf" "M2_M1" "symbolic") t)
But I dont know the rule to keep double contact/via in the router .Please help me.
Siva
  • craigth
    craigth over 15 years ago
    Siva,
    What release of Virtuoso and VCAR are you using?
    What do you mean by “vcar rules file”? Do you mean the .do file?
    In parallel to a response to the questions above, reference the following VCAR commands in the IC615 Virtuoso Chip Assembly User Reference Manual. These commands allow you to specify and control multiple vias during routing.
    • use_via http://support.cadence.com/wps/PA_DocumentViewer/pubs/iccraft/iccraft6.1.5/cmd_circuit/use_via_descriptor.htm
    • use_array
    •  enforce_use_array_rule http://support.cadence.com/wps/PA_DocumentViewer/pubs/iccraft/iccraft6.1.5/cmd_sw/enforce_use_array_rule_key_set.htm
    You can also reference some good information in the IC615 Virtuoso Chip Assembly User Guide
    •  Via Arrays and Via Images       http://support.cadence.com/wps/PA_DocumentViewer/pubs/iccausr/iccausr6.1.5/chap7.html#98914
    • Choosing to use Via Arrays or Via Images       http://support.cadence.com/wps/PA_DocumentViewer/pubs/iccausr/iccausr6.1.5/chap7.html#829052
    • Via Adjacency Rules for Via Arrays      http://support.cadence.com/wps/PA_DocumentViewer/pubs/iccausr/iccausr6.1.5/chap7.html#828997
    If you mean the oa techFile and/or constraint definition as the “vcar rules file” you should reference the following sections in the Virtuoso Chip Assembly User Reference Manual
    • OpenAccess  http://support.cadence.com/wps/PA_DocumentViewer/pubs/iccraft/iccraft6.1.5/toc/iccraftTOC5.html
    • Mapping Constraints to Virtuoso Chip Assembly Router  http://support.cadence.com/wps/PA_DocumentViewer/pubs/iccraft/iccraft6.1.5/oa/mapping_constraints_to_vcar.htm
                oaViaDefArrayValue      use_via class rule (from nondefault routing constraint)
    Craig T.
  • craigth
    Siva,
     Sorry about the formatting. Below is a reformatted version of my response.
    Siva,
    • use_array
    Craig T.
  • PSRK
     HI Craig...
     I didn't mean the do file. We do specify a rules file in "export to router" window. I check the box "Use rules file" and the rules file in which I define the Minimum widths minimum spacings and the vias to be used. For example, I have attached the rules file. please look into it.
    Siva
  • PSRK
     Hi Craig,
    I referred to the use_via and use_array commands from the links that you have posted. My issue is solved now. I added these lines to my do file.
    select all nets
    define (group group1 (selected))
    circuit group group1 (use_via (use_array M2_M1 1 2))
    ##Standard Routing Command
    route 25
    clean 2
    route 50 16
    clean 4
    I was wrong with the rules file. Thanks for your response.
    Siva
  • Peter123
    Peter123 over 14 years ago
    Hi Siva,
    I'm facing the same issue as you now,
    I can't find the box "Use rules file" in my IC6.1.5 startup form.
    can you pls show me how is your form look like?
    Snapshot below is my starup form.
    peter
  • PSRK
    PSRK over 14 years ago
    Peter,
    I don't see your attachment. Did you attach it properly?
    Siva
  • PSRK
    Attached is my export to router form. click on the exporttoroute.png image.
    Siva
    In IC615, because it is working directly on the OA database, it will use the technology rules directly from OA - and hence there's no option to specify a rules file. The thing that Siva was describing before is implemented with a "do" file, and you still have the ability to specify one of those.
  • Peter123
     Hi Siva,
     For some reason, i can't upload my snapshot.
    Your form is like IC5.1.X version, which i used to have.
    But, I'm in IC6.1.5 now; the form looks totally diff.
    -peter-
  • Peter123
    Since there is no rules file in OA database,what should i do in order to use the command "use_via"?
    -Peter-
