  3. Diffstbprobe
  • Replies 11
  • Subscribers 136
  • Views 35671
Diffstbprobe
DaleStubbs
DaleStubbs over 14 years ago
I am currently running virtuoso version 6.1.5 and was reading on sourcelink about the diffstbprobe. In the past I have used the cmdmprobe with mixed results. I have a few quesitons:
1.Does the diffstbprobe work as in http://www.designers-guide.org/Analysis/diff.pdf.
2.Is this probe called in the same way as cmdmprobe using the ADE->analyzes->stb option?
3. Is it possible to use this during a transient simulation? I thought it was possible to set "actimes" to a time to run stb sim, and "acnames" to stb. This does not appear to be working in 6.1.5. Am I allone in seeing this, or am I not setting it up correctly.
4. Is it possible to do it during a transient simulation, if the simulator is APS?
Dale
    Andrew Beckett over 7 years ago in reply to FormerMember +1
    Those pictures are too small to see what you you're trying to illustrate.
    Andrew Beckett over 7 years ago in reply to Frank Wiedmann +1
    Thanks Frank. Your eyesight is better than mine! Andrew.
  • RFStuff
    RFStuff over 7 years ago in reply to Frank Wiedmann
    Thanks a lot Frank.
