  3. mosfet multipliers & fingers
  • Views 8342
Analog layout
Analog layout over 14 years ago
 Why they mention multipliers & fingers seperately?
ex:- m=10, f=10
but why they mention like this
f=100.
So please any body tell me why we need to place multipliers insted of using only fingers?
 Thank you,
  Sivaji
  • Quek
    Quek over 14 years ago
    Hi Sivaji
    In mosfet bsim models (version 3v3 and above), m and nf affects how other parameters (e.g. stress parameters) are calculated and so affects circuit behaviour. It is not really correct to say that we should place m instead of nf. You can use either depending on your needs. The only thing to take note is that both schematic and layout must be consistent. E.g. if m=3 and nf=1 is used in schematic, then layout should have 3 unabutted mos devices with 1 finger each. Having 3 abutted mos devices mean m=1 and nf=3. This can result in wrong results for sensitive circuits like bandgaps.
    Best regards
    Quek
  • Analog layout
     just go through attachment and let me know. Why we need to specify m and nf. insteed of using m we can use only nf.?
    Quek already answered this in a general way so it's unclear what else you need to know. Your question is rather vague and a more specific answer would require understanding of the particular choices for the specific design kit/technology you're using. Such questions would be best placed to the provider of the design kit.
