  3. Skill
  • Replies 9
  • Views 17963
Skill
SarathKumarG
SarathKumarG over 14 years ago
Hi guys,
I want to create streachable metal bus using skill code.Plz let me the the idea about how to create it.
    Use rodCreatePath. Here's an example of creating a bus with this:
    /* abCreateBus.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Mar 30, 1999
    Modified   Mar 20, 2009
    By         A.D.Beckett
    An example of creating a bus using ROD.
    The points could of course be specified by something like enterPath()
    in practice.
    Mar 20, 2009. Added new optional busPrefix to allow wires the be
    on named nets.
    SCCS Info: @(#) abCreateBus.il 03/20/09.12:59:54 1.2
    *        abCreateBus(cv layer points numWires [busPrefix])        *
    * Create a bus with given points, in the specified cellView, with *
    *                 the specified number of wires.                  *
    procedure( abCreateBus(cv layer points numWires @optional busPrefix)
      let( (tfId layerWidth layerSpace offsetPaths)
        /* get technology file information */
        tfId = techGetTechFile(cv)
        layerWidth = techGetSpacingRule(tfId "minWidth" layer)
        layerSpace = techGetSpacingRule(tfId "minSpacing" layer)
        /* construct the list of sub paths */
        for(bit 1 numWires-1
          offsetPaths=tconc(offsetPaths
            list(
              ?netName when(busPrefix sprintf(nil "%s<%d>" busPrefix bit))
              ?layer layer
              ?justification "left"
              ?sep layerSpace*bit + layerWidth*(bit-1)
        rodCreatePath(
    ;      ?name "bus"
          ?netName when(busPrefix sprintf(nil "%s<0>" busPrefix))
          ?layer layer
          ?pts points
          ?width layerWidth
          ?justification "center"
          ?cvId cv
          ?offsetSubPath car(offsetPaths)
        ); let
  • kalikrishna
    kalikrishna over 14 years ago
          Thank you for your response. It is very helpfull for me.
    I have one doubt on above code. on that for net name you use
     when(busPrefix sprintf(nil "%s<%d>" busPrefix bit)). I want to know, what is the use of this command?
    In this one disadvantage, we have to enter the points everytime.
    Is there any better solution? please let me know..
    That line defines the net name for the bus wire. If ?busPrefix is passed to the function (e.g. as ?busPrefix "mybus"), each wire of the bus will get a net name of mybus<0>, mybus<1> etc. If you don't specify it using ?busPrefix, the wires will have no net assigned - they'll just be simple shapes.
    If you're asking about digitizing the points rather than typing them in, the comment at the top gives the hint. You could write something using the enterPath() function to collect the points before calling this function to create the bus.
    If using IC61 (e.g. IC615) there is a Create->Wiring->Bus command, so if that's what you want, no point reinventing the wheel. This allows you to interactively enter a bus, including changing layers and inserting vias, etc, etc.
  • kalikrishna
    Thank you Andrew,
                                  By using this code, we can't draw BUS by clicking mouse as where we want like multi part path.
    plz let me know any suggestions
    Thank You
    I explained how you could write something using enterPath() - if you search using the community search in this forum for "enterPath" you will find some examples of using this. I also explained how there's a built-in feature in IC61X. I could also have mentioned that in IC5141 you could use the "turbo toolbox" to provide this functionality - this is shipped as standard.
    So I'm not really sure what more suggestions I can give (other than writing the code for you, which I don't have time).
    I will even paste some code in here which shows enterPath being used for another purpose:
    /* abGuardRing.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Sep 13, 2002
    Modified
    By
    This code defines two functions and a key-binding that allows the
    automatic creation of an arbitrary guard-ring structure.
    Could do with a few more comments...
    SCCS Info: @(#) abGuardRing.il 09/13/02.14:03:39 1.1
    hiSetBindKey("Layout" "<Key>F10" "abCreateGuardring()")
    procedure(abCreateGuardring()
        unless(boundp('abCreateGuardringForm)
            abCreateGuardringOptionsForm()
        enterPath(?prompts list("Enter points for guard ring")
            ?doneProc "abCreateGuardringDoneProc"
            ?points nil
            ?addPointProc "abCreateGuardringPointTracker"
            ?delPointProc "abCreateGuardringPointTracker"
            ?form abCreateGuardringForm
            ?alwaysMap t
            ?pathWidth abCreateGuardringForm->diffWidth->value
    procedure(abCreateGuardringOptionsForm()
        let((diffWidth)
            diffWidth=hiCreateFloatField(
                ?name 'diffWidth
                ?value 10.0
                ?callback "abChangeGuardringWidth()"
                ?prompt "Diffusion Width"
            hiCreateAppForm(
                ?name 'abCreateGuardringForm
                ?formType 'options
                ?buttonLayout 'HideCancelDef
                ?fields list(
                    list(diffWidth 0:0 400:30 100)
    procedure(abChangeGuardringWidth()
        ; need this to stop recursion (not sure why)
        unless(abCreateGuardringForm->currentWidth==
            changeEnterFun(
                'enterPath
                ?points abCreateGuardringForm->points
    procedure(abCreateGuardringPointTracker(win points)
        abCreateGuardringForm->points=points
    procedure( abCreateGuardringDoneProc( win done points )
        let((
            (MPSDwid abCreateGuardringForm->diffWidth->value)
            (MPSDoverM1MT 0.7)
            (MPSDoverM1MC 1.30)
            (MPSDoverM1MCfuse 1.25)
            (MPSDoverMMOX 0.0)
            (MPSDoverMLOC 0.5)
            (MPSDoverSCE 0.9)
            (M1MCfuseWid 0.5)
            (M1MCspacing 0.5)
            (M1MCwidth 0.4)
            (cv geGetEditCellView())
            rowsOfConts availWid startOffset subRects
            ; reset points for next invocation
            abCreateGuardringForm->points=nil
            abCreateGuardringForm->currentWidth=nil
            ;abChangeGuardringWidth()
            ; now compute...
            availWid=MPSDwid-2*MPSDoverM1MC+M1MCspacing
            rowsOfConts=fix(availWid/(M1MCfuseWid+M1MCspacing)+0.001)
            startOffset=(rowsOfConts*M1MCfuseWid+(rowsOfConts-1)*M1MCspacing)/2.0-
                M1MCfuseWid/2.0
            for(contRow 0 rowsOfConts-1
                subRects=cons(
                    list(
                        ?layer       '("M1MC" "bip2")
                        ?beginOffset -MPSDoverM1MC
                        ?space M1MCspacing+M1MCfuseWid-M1MCwidth
                        ?choppable t
                        ?sep -startOffset+contRow*(M1MCfuseWid+M1MCspacing)
                        ?gap 'minimum
                    subRects
                subRects=cons(
                    list(
                        ?layer       '("M1MC" "fuse")
                        ?beginOffset -MPSDoverM1MCfuse
                        ?width M1MCfuseWid
                        ?choppable t
                        ?gap 'minimum
                    subRects
            ) ; for
            when(done
                grfig = rodCreatePath(
                    ?cvId       cv
                    ?layer      '("MPSD" "bip")
                    ?width      MPSDwid
                    ?pts        points
                    ?choppable  nil
                    ?encSubPath list(
                        list(
                            ?layer     '("MMOX" "bip")
                            ?enclosure MPSDoverMMOX
                            ?choppable nil
                        list(
                            ?layer     '("MMOX" "CHK")
                            ?choppable nil
                        list(
                            ?layer     '("MLOC" "bip")
                            ?enclosure MPSDoverMLOC
                            ?choppable nil
                        list(
                            ?layer     '("SCE" "bip")
                            ?enclosure MPSDoverSCE
                            ?choppable nil
                        list(
                            ?layer     '("M1MT" "bip")
                            ?enclosure MPSDoverM1MT
                            ?choppable t
                    ?subRect  subRects
  • SarathKumarG
     Thanks Andrew,
                            I write sample programme for displaying GUI optionsform window.When i executing it shows    the ERROR "formStruct@0xd8ca808".plz let me know what is this error.Below is my programme
     hiSetBindKey("Layout" "<Key>F11" "bus()")
    procedure(bus()
    unless(boundp('busform)
            busform()
    procedure(busform()
     let((enterpoints)
    enterpoints=hiCreateFloatField(
                ?name 'enterpoints
                ?value  nil
                ?prompt "wantedpoints"
            hiCreateAppForm(
                ?name 'busoptionsform
                ?formType 'options
                ?fields list(
                    list(enterpoints 0:0 400:30 100)
    Thank you.
    That's because nothing is displaying the form. If it's an options form, you'd have to reference the form object (busoptionsform) from the enterPath() call with a ?form argument - just as I did in the abCreateGuardring function. Alternatively, if you make the form a non-options form (?formType 'nonoptions and a suitable ?buttonLayout - the one you've picked is only relevant for options forms), you can then display it with hiDisplayForm().
    Right now, all you're doing is creating the form, and the function returns the last thing in the function, which is the return value of hiCreateAppForm, which is the handle to the form data structure.
  • SarathKumarG
    Thanks Andrew,
                            I created the GUIform.But i dont know how to take the value entered in field ofGUI &how  to assign some variable to that value.Plz let me know any suggestions.
    Thank You.
    My first suggestion would be for you to show what you've done. Without that I'd have to give you every possible solution based on me guess as to how you might have implemented it.
    Please try to put yourself in the shoes of whoever is trying to help you out in the forum - do they have enough information to be able to answer you? Remember that this is a community forum, and we are all volunteers (including folks from Cadence who respond here - it's not part of our daily job to do this) and are responding in our free time. We're all busy people, so the more precise and complete the question, the more likely it is you'll get an answer.
