  3. skill syntax
  • Subscribers 133
  • Views 14747
skill syntax
SarathKumarG
SarathKumarG over 14 years ago
 Hi guys,
             I want basic syntax for skill code to creat a meta path.Can any one know plz let me know.Thank you.
    What's a "meta" path? (perhaps you meant "metal" path?). Anyway, look in the documentation (cdnshelp if using IC61X, cdsdoc if using IC5141) and search for the functions dbCreatePath or rodCreatePath if you want a higher-level function which supports multi-part paths. There is detail on the syntax and examples.
