  3. How to set the senstype during sens analysis in ADE L?
  • Subscribers 133
  • Views 16048
amwygah
amwygah over 14 years ago
hello,everybody:
After I use the sensitivity analysis in ADE L, I print the sens result in the result box. Then, I found that the sensitivity result is given by
S(F,P)=dF/dP rather than S(F,P)=P/F * dF/dP
And, after I search it in many references, I find that the value of senstype would deside which formula will be used.
But unfortunately, in sensitivity analysis ,defaultlly, the senstype=partial,which use the first formula.
if you want to use the second formula, you need to spectify that senstype=normalized .
But, I donot know where and how to change this value. Could anybody help me?
  • SharksFan
    SharksFan over 14 years ago
    Have you tried this line in your .cdsenv:
    spectre.opts    senstype    string    "normalized"
    or  adding this line in your .cdsinit
    envSetVal("spectre.opts" "senstype" 'string "normalized")
    You can query your present value of these from the CIW by entering:
    envGetVal("spectre.opts" "senstype")
    Hope this helps
    In the UI, it's under Simulation->Options->Analog (in IC5141 it's near the bottom, in IC61X it's on the Miscellaneous tab). It's not under the sens analysis as an option, because sens is actually a control statement rather than an analysis in spectre (so doesn't have any direct options - so it appears under "spectre -h options" rather than "spectre -h sens").
  • amwygah
    thanks sharkFan.
    But your expression doesn't wok.
  • amwygah
    thanks Andrew.
    You are correct. Now the results is listed in the form of senstype = normalized.
