  3. Loading individual simulation results from a parametric...
  • Subscribers 133
  • Views 15229
Loading individual simulation results from a parametric sweep
Teeravis
Teeravis over 14 years ago
I'm running into the "unable to allocate memory for transistion file build ctrl values (read ctrl 1 init)" issue in ic5.1.41.500.6.146
 This post suggests dumping files in 2gB chunks. www.cadence.com/.../13134.aspx
My files are less than 2gB but I have about 5 simulation results produced by the parametric sweep.
Each tran.tran.trn is about 600M, so it gets through about 3 before this command chokes
 ocnPrint( VT("/op") ?step 1.0/5.0e6 ?output "~/asdf.txt" ?numberNotation 'none)
My question is. Can I load individual results from parametric simulations. I have 5 directories with 5 different tran files. I currently select my results through the ade environment using results/select/schematic.  When I do this it is loading the results for all 5 sims.
Essentially is there any way for me to get access to the tran.trn files individually and execute this command.
Or is there some way to by pass this from happening?
Any help would be greatly appreciated.
 Travis
  • Teeravis
    Figured it out.
    .trn files can be loaded and viewed with simvision.
    Samples can be exported from the calculator.
