  3. ASSURA 41 lvs problem
  • Subscribers 133
  • Views 15089
jorgevdelacruz
jorgevdelacruz over 14 years ago
Im using IC65 with ASSURA41 and i having a problem with the LVS. When i run it it has the following error:
Starting dfIIToVdb...
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
INFO (DB-170019): Error: failed to initialize OpenAccess because:
ConstraintDef already exists
*WARNING* Translation abnormally terminated!
*WARNING* aveng exit with bad status
***** aveng fork terminated abnormally *****
*WARNING* Status 256
*WARNING* Assura execution terminated
Could you help me?
Thanks in advance
Jorge
    Jorge,
    I've not found any reports of the same error. So, first check that you're using the right build of ASSURA41 to go along with IC615 (assuming that's the version you meant), and do not have $OA_HOME set. Having done that, if it doesn't fix it, please log a service request at Cadence Online Support.
  • jorgevdelacruz
    Andrew,
     Thanks for your answer. The variable $OA_HOME was set, i changed it and the lvs is working normally.
    Jorge
