  3. IC514 menus messed up via NX
  • Subscribers 133
  • Views 14850
edogd1
edogd1 over 14 years ago
I am using IC514 via NX and periodically the menus in ADE, Virtuoso, and icfb get mixed up.  I have run my mouse through every menu possible to get the correct menus back.
Is any one seeing this problem too?
    With NX you can set the speed of your line to various settings, eg ADSL, WAN, LAN and others. As you go to lower bandwidth connection settings, it drops detail and can lead to this kind of effect - I've seen it happen. Check if it's set to something other than LAN, and if not, try setting to LAN to see if it is that (this in the configuration options for the connection you're using, if my memory is right - not in front of computer right now).
    If that's not it, I suggest you contact NoMachine as it's unlikely to a Cadence software issue if it doesn't happen on other X displays.
  • edogd1
     Thanks for the tip Andrew.  I tried but I still get the same problem.  I have also noticed this on occation, though less often, when directly login into a redhat box.
