  3. ahdlcmi lib compilation & simulation scripting
  • Views 1114
Steve Mikes
Steve Mikes over 14 years ago
Hi all, I'm trying to write a python script that find optimum values for tuning parameters in my circuit.
The problem is that every time it runs a sim, there are several lines worth of "Compiling ahdlcmi module library" which in sum take longer than the actual sim itself. I usually use spectre MDL for sim scripting, but MDL is lacking in advanced functionality. Is there a way somehow to do the compilation only once and reuse it for successive simulations?
 Hope I was clear enough, thanks!
  • Quek
    Quek over 14 years ago
    Hi Kampfmeister
    You can set the following shell variables and see if it helps:
    setenv CDS_AHDLCMI_DIR /your-path/ahdlcache
    setenv CDS_AHDLCMI_DIR_ALWAYS YES
    Please use "spectre -h veriloga" for more info.
    Best regards
    Quek
