  3. How to increase the tolerance of capacitance in Assura LVS...
  • Views 16511
How to increase the tolerance of capacitance in Assura LVS?
shushanik
shushanik over 14 years ago
Dear Community,
Can anybody help me with this issue:
I want to increase the tolarane of CAP1 ,but no value does affect on result.
In compare.rul file it is described this way:
compareParameter("CAP1" compCAP1 ),
while compCAP1 is a procedure:
procedure( compCAP1( lay, sch ) ; checks props: value
  prog(( )
        terrormsg = ""
    modelName = lbcGetModelName( lay sch )
    compCAPmod( lay, sch )
    compCAPmodWL( lay, sch )
    if( terrormsg == "" then return( nil )
    else
      return( terrormsg )
Additional description of CAP1 seems has no effect on result.
compareParameter("CAP1" percent("c" 200 ))
Can you please help me to understand this syntax ,as I am new to assura and it’s  a black box for me yet.
Thanks in Advance,
Shushanik
  • shushanik
    Dear Community,
      prog(( )
            terrormsg = ""
        else
          return( terrormsg )
    Thanks in Advance,
    Shushanik
  • Quek
    Quek over 14 years ago
    Hi Shushanik
    If I understand the question correctly, you have added 2 compareParameters cmd for CAP1 in the compare.rul file and is puzzled why the 2nd cmd (percent("c" 200)) has no effect. This is expected as the 1st cmd overwrites the 2nd cmd. You will have to incorporate some parameter comparison codes inside compCAP1 procedure. Please refer to Assura command reference for some sample codes under description for "compareParameter" cmd.
    Best regards
    Quek
  • shushan
    shushan over 14 years ago
     Hi Quek,
    Thanks a lot for quick responce.
    You have answered to my question.I will  try to go into compCAP1 procedure and make according changes.
    But the thing is,that compCAP1 procedure(as it supposed to be) referes to other capacitors as well,so I just can't simply change it.
    Thanks a lot and Best Wishes!,
    Shushanik
  • Quek
    Hi Shushanik
    In that case, you can always create another procedure for CAP1 device. : )
    Best regards
    Quek
  • shushan
     Correct!!! )
    I just didn't want to make a big changes in the deck.
    Thanks a lot!
