  3. How to rename ok button?
  • Subscribers 133
  • Views 15361
bobbygang
bobbygang over 14 years ago
   I created a form and I wanted to rename button "OK" "Apply" with new name "Create and Cancel" "Create". I kept the button "Cancel" and "Defaults". I wrote the button defination code as following shown
?buttonLayout '(Empty  (Create\ and\ Cancel hiFormDone) (Apply hiFormApply)  (Cancel hiFormCancel) (Default hiFormDefaults))
but when I run it I found all button woks except "Create and Cancel" and I got the feed back information "Form button "OK" is not available.Can you tell me the reason?
Best Regards,
Bobby
    Bobby,
    It seems there is an assumption as to their being an "OK" button on the form - I can't see any reports of this.
    Workaround would be to probably call hiFormApply() and then hiFormCancel in your callback.
  • bobbygang
       It works. But I don't understand the principle. If I use following code,
    ?buttonLayout '(Empty  (Create hiFormApply)  (Cancel hiFormCancel) (Default hiFormDefaults))
    I use "Create" replace with "Apply" button, and it also works.  Why can't I use ""Create and Cancel" replace with "OK"?
    Best Regards,
    Bobby
    Bobby,
    Because there's something specific in the hiFormDone function which expects the OK button to be there. I don't know why that is...
    If you don't like that, please log a service request with customer support so that we can consider changing this dependency. I can't see any particularly strong reason why it has to be this way.
