  3. Why the AWD only plot up to ~20ms
  • Subscribers 133
  • Views 15043
SUEE
SUEE over 14 years ago
Hi  all,
 I run ADE simulation and found that the AWD plots the simulation result only up to ~20ms !
The simulation log showed the simulation is finished, but why the AWD only plots the result up to ~ 20ms?
The disk is not full.
 Thank you !!
  • sunilm
    sunilm over 14 years ago
    This might be a known problem in the AWD/Wavescan with sst2 database.
    Try using psfbin .
    You can check this  solution for more details.
    Sunil
  • SUEE
    Thank you!
    After key in envSetVal("spectre.envOpts" "simOutputFormat" 'string "psfbin") into the CIW, it works now.
